by YouTube
2
Activity
<100
Summary
Summary
This activity is used to manage the system's power activities.
Using this activity you will be able to easily manage your system’s power activities such as Shutdown, Restart, Lock, Logoff or Sleep.
As an Input you only need to enter the PowerType: Shutdown, Restart, Lock, Logoff, Sleep.
Features
Features
Easy way to Shutdown, Restart, Lock, Logoff or Sleep the PC.
Additional Information
Dependencies
n/a
Code Language
Visual Basic
Runtime
Windows Legacy (.Net Framework 4.6.1)
License & Privacy
MIT
Privacy Terms
Technical
Version
1.0.2Updated
February 18, 2020
Works with
Developed and tested using UIPath studio version 2019.4.3
Certification
Silver Certified
Tags
Support
UiPath Community Support
