by YouTube
0
Solution
<100
Summary
Summary
IGT’s Refund Automation using RPA is a rule based task automation solution for high volume of refund processing cycle in Finance Operations for LCC Airline.
The solution performs the steps for checking refund eligibility and approves it for payment release post amount validation. Leveraging the integration with Airline’s PSS APIs the solution also performs calculations as per the defined business rules.
A time consuming repeatable yet essential pre-requisite task of opening / closing flight is also automated.
For any fall outs in the RPA automated process that require human intervention, exceptional scenarios are recorded and notified to be managed manually.
The solution is scalable and can be trained for complex scenarios which can eventually do 90 or 95 % of the work with very few exceptions to be dealt by human.
Features
Features
50% reduction in completion time of a refund transaction High accuracy in refunds 30% reduction in Operational Cost Lower compliance and Business risk The solution solves the issues of backlog caused by time lag, quality, accuracy and speed of processing refunds. Also as the solution is built to perform the mundane repeatable task, the human can take care of the complex ones increasing the enterprise efficiency, thus reducing overall expenditure.
Additional Information
Dependencies
The solution is dependent on the following- 1. Airline PSS- Navitaire suite of applications- Sky Speed/ New Skies GoNow API availability and access to Navitaire system is also a dependency for this solution. 2. MS Office
Technical
Updated
August 19, 2020Works with
Solution developed and tested with UI Path version – 2017.1.6522 Works with all versions of MS Office Solution developed for Navitaire version 3.4.11 Does not work with Office 365 web interface
Tags
Support
UiPath Community Support
